Plunge lock for TS 55 & 75
Lucazzstorm
Any plans to engineer a switch or lock/lever of some sorts to allow users to lock saw down at desired depth. (Eliminate plunge action?). I personally could use it quite often.  Thanks!!
Not that I am aware of. And please don't post any modifications  of that type here on FOG.
Thanks,
I would simply buy a standard portable power saw ... in fact I did, I have two Hitachi saws for that.
Funny thing is I tend to cut most things from a plunge perspective these days. The Hitachi saws see little use (plus that spay sawdust everywhere).
I agree very much with Seth, any modification to lock a plunge saw would be potentially dangerous and I'd never consider doing so myself.
Good point.  Quite honestly it's not something I do often and yes the mess sucks.  My solution ultimately is just the need for a MFT.  the short rail on a pivot would allow me to make the quick cross rips.  I just need to figure out a good way to raise one hight wise before I buy due to back issues.  Bending over is bad news for me.
Forgot to mention I would never attempt to modify any of my babies!  It's hard to perfect perfection.  I'd be better off running it over with my truck.  Same end result less time!
First, welcome to the FOG!
I seriously doubt that such a product would ever be made available due to the fact that it would allow the blade to start up without it being in a guarded position.  Might be ok in some situations but not sitting on a lap  [eek].
If all you are looking to do is make quick short crosscuts a simple board with 2 or more 20 mm holes and some Qwas rail dogs will work.  If you are doing a consistent thickness you can block up the tail.
Here is a link:  http://festoolownersgroup.com/festool-jigs-tool-enhancements/did-you-get-a-mft3-or-a-dust-deputy-for-christmas/
Take a look at the steps tool images and you will understand what I am talking about.
Hi
Why not get the new TS55R it seems to be doing what you're after. That's why it got recalled.  [big grin]
Sorry, just had to.
Festoolviking
Raising the pivoting rail or the saw?
There are a couple of saw holders posted on here.
This thread has some discussion and links to ideas.  http://festoolownersgroup.com/festool-tools-accessories/saw-holder-for-mft/
Something came to mind
There is a Festool-part that can be used for this application but it's NAINA and part of the CMS-TS Module.
Enough said.  [wink]
Festoolviking
I would use this for sure, I understand why it will probably never happen though. If you have ever ripped a 45 degree miter in 36' long 1 1/2" material, then you know how tiring it is on your hand to plunge on the 45!! I would still plunge at the beginning and un-plunge at the end, but inbetween it would sure make things easier.
How about a safety so that you can't start the saw with the plunge-lock on, but it could be plunged-locked while running…
You are describing the Mafell KSS saws. I love my Festools, but as a remodeler I've found the Festool track system rather limiting, and have transitioned to the Mafell track system for this reason. Self-aligning tracks, faster connections, better clamping options, better saws.
For a TS-55 equivalent, you'd be looking at the KSS 400, which takes the same 160mm blades as your TS-55.
To replace a TS-75, you'd be looking at the KSS-80, which takes a 30mm arbor, 230mm blade, and 2300 watts power, compared to 1600 watts for the TS-75.
Take your pick!  [big grin]
