dicktill
Hi all,
I'm a bit confused about using a plunge saw (specifically the TS 55, but applicable to all) on a guide rail, and what minimum length of rail you need. Obviously it's best to have enough length to start the saw "outside" of the material to be cut, but what if you don't have enough length, such as using a 55" rail to crosscut a 4' sheet of plywood? Is it wrong to start the cut by plunging? After all, it IS a plunge saw. The thread http://festoolownersgroup.com/festool-tool-reviews/carlson-designs-reviews-the-ts-55-req/ seems to indicate that this is wrong:
I especially don't understand the part about "That will quickly pull the saw to full depth unexpectedly".
Thanks, Dick
Rick Christopherson said:... My biggest concern is where he is shown plunging the blade on a few cuts. The first one wasn't even a plunge cut, but he just didn't back the saw up far enough before the cut. That will quickly pull the saw to full depth unexpectedly, and is probably a fairly common mistake with new users. ...
Thanks, Dick
