dicktill said:
Still haven't figured out for sure how to support "the-top-of-the-box", but recently ordered a "V-Groove Face Frame Joining" router bit along with a "Square Edge 3/16" Beading" router bit from Eagle America (their P/N 100-7925 for the set). I'm thinking of running the vertical face boards all the way to the bottom of "the-top-of-the-box", and have a dado on the back of it to support "the-top-of-the-box". (Sorry, I'm new to all this, so don't know the correct terms.) And also to have dado's on the top side of "the-top-of-the-box" into which the vertical dividers will be glued. Advice here would certainly be welcomed!
Dick:
I was wondering how you were doing on this project?
I have been a bit busy to respond to your questions.
Without a drawing it's difficult to understand your proposed construction.
You will definitely need to have a back (dado-ed etc.) on the case that spans the 78" space to create enough strength to span that length. Like a torsion box, the back will add strength and prevent sagging of the top case.
If you haven't already built this, can you post a quick pencil drawing?
Tim
