sofa_king_rad
- Mar 26, 2016
I've been searching and searching and i'm probably just not using the right keywords.
In a build where there is a plywood panel like a chest or whatever, what are methods used to make then more decorative?
I've seen things where the plywood tapers down at the edge or bead board look grooves or similar cut into it. However I think the pieces i've seen that on the panel was MDF. Can you do the same things with plywood?
Any videos/tips/resources for this kind of info? I'm really interested in taking some 1/2" Ply down to 3/8" or 1/4" at the edge for the dado in the frame. Or maybe some simple decorative lines in it.
