Stoli said:Frank,
The clamps are still needed during assembly to keep the pieces from moving when the screw goes in.
WelshWood said:Hey guys,
Looking to get a pocket hole jig soon and wondering what you would recommend? Seems like alot of people go for the kreg version, but after seeing the UJK versions i'm a little torn..
Thanks in advance,
~WW
neeleman said:WelshWood said:Hey guys,
Thanks in advance,
~WW
I also choose the UJK Pocket Hole Jig for the following reasons:
- It's metric
- It uses regular Torx screws and no Robertson like Kreg
- It can do 12 mm board on the same Jig
- It has a vacuum hose connection
- Mainly made of steel/aluminium, few plastic parts
- Sold (made?) by Axminster
An I like it, it does what it promises!
I especially like the Centrotec compatible drill bit and the long Torx screw bit which are available from Axminster as well.
Ed Bray said:...but the real issue comes when you try to join both bits of wood without them moving out of sync. I have a couple of Kreg clamps but still find they move
Ed Bray said:Stoli said:Frank,
Exactly, the K5 jig is as good as any other at drilling the holes, that isn't the issue, it is that as the screws go in they have a tendency to move the wood which then makes slightly offset joints.
WelshWood said:As a side note.. where do you find the best place to buy the screws/plugs from?
eddomak said:Someone here had a good suggestion of drilling 2 Kreg holes right next to each other (especially at the end of the pieces), and using the right angle clamp in one hole whilst driving the other. This gives a lot firmer grip (and therefore less slippage) than using the next pocket hole down, which is often 15cm away.
