I have a Mahogany table top that measures 3.5'x11' and is 1-3/4" thick.
The finish started with a waterbased grain filler, then sanding sealer and 5 coats of the waterbased poly brushed on.
Then two more coats of the waterbased poly were sprayed on.
The finish is gloss. The last coat was sprayed this past Sunday.
I would like to polish or wax it to retain the gloss and get a super smooth feel, removing the slight gritty feel it has now.
What grit and what type of wax or compound should I use?
Thanks!
Thanks!
