Used this automotive lacquer on a table top with an epoxy resin inlay.
Though it is advertised for use on wood also.
"A high-performance 1K clear lacquer clearcoat, which gives a crystal clear finish to metal, wood and painted surfaces. An acrylic lacquer that can be applied over all water and solvent-based basecoats. It has a rapid drying time, and provides a durable, UV and petrol-resistant finish."
The finish on the walnut and ash is stunning but have a series of dimples on the resin inlay.
Base coat is sanding sealer.
I will probably sand it down and try again but if anyone has any pointers they would be appreciated.
Perhaps I need to try a lighter coat?
Wish I knew how to post an image.
