billberner
- Dec 31, 2015
I just bought a new Kapex 120 and honestly am pretty underwhelmed with it. I am hoping there are a couple things forum members can help with:
1) the left laser is so dim you can barely see it. In one areas, it's completely dark. That makes the laser useless. I think this may be related to the fact that when the saw came, the left laser was off by at least 1/8". I had to adjust it pretty much all the way to get it to line up to the cut, now it's dark
2) the right 'stop ruler' (the upper part of the right side of the fence is very wobbly, even when locked down. I have not scoured the manual completely, but so far have not found a way to fix that although I intend to follow the instructions for removing and replacing it to see if that helps (I am away from the shop for the weekend)
Other things I don't particularly like:
- Dust collection is not great with a CT36 and the wider hose. Certainly worse than I had with my old DeWalt that had a dust shroud attached to my Oneida.
- With the MF mini table, there is not much room to reach under to loosen or tighten the extensions. that is particularly a problem because the extensions are pretty wobbly to start with, so I try to keep them tight.
The entire setup was >$2500. For that I figured I'd be blown away and that hasn't really happened at all. I haven't changed a blade yet, I hope when I go to do that, it will be much simpler than for the DeWalt, which was kind of a joke.
Thanks in advance for any help or comments.
