GreenGA
- Oct 11, 2007
Question... We've been asked to reface a brick fireplace with black granite tile around the firebox and hearth and MDF for the overmantle and the actual mantle will be the 2.25 inch Tennessee Sandstone noted in the subject.
We are planning to support the mantle at each end with a 8.5 inch solid column ( 2x material and plywood sandwich wrapped in MDF) and also rest the rear of the mantle on the .5 inch thick tile mounted on the fireplace face. The distance between the columns will be 58 inches. The mantle will be about 14 inches deep.
We're wondering if the two columns and the lip of the tile will be sufficient to properly support the mantle and prevent it from sagging in the future.
Thanks in advance.
Thanks in advance.
