MrToolJunkie
- Jul 6, 2009
Hi everyone,
I am in the middle of redoing my master bath and I stripped all the old tile off the walls and floor -- the substrate is a mortar bed approximately 3/4 inch thick. I need to get to the valve assembly for both the shower and the Roman tub and I was going to use a grinder and diamond wheel to cut an access hole for each. I want to avoid chiseling out the entire mortar bed and would prefer to keep whatever I can intact and then patch a few places where chunks came off with the tile and a couple of hairline cracks. I was going to use two coats of Red Gard over everything before laying the new tile.
Here are my questions/assumptions and would love to hear from the experts on this forum for advice:
1. Is above approach OK with keeping the existing mortar bed? I have had no leaks at all and the entire structure seems to be in great shape and sound with exception of the places I damaged when taking the old tile out. I figured the Red Gard would be added insurance to prevent future leaking.
2. What should I patch the access holes with? Should I install new lath in those areas and then rebuild the mortar level with the existing bed or is there a better/different approach? I was thinking I could install cement board and then add a thinner layer of mortar or was wondering if you can layer the cement board to get the surface flush, using webbed tape and mortar around the seem where the "patch" and old mortar bed meet? Of course I would install some 2x behind it for support. One access hole will be approximately 16 inches by 12 inches and the other one in the shower would be 16 inches by 40 inches or so -- enough to get at the valve assembly and the top of the pipe where the shower head will go.
3. I need to install two 2x cross members to secure the new valve in the shower and the top of the pipe where the shower head goes through the wall. Is it acceptable to use wood screws or some other building screw for this purpose rather than nails? I know this might sound like a dumb question but I just want to make sure that what I install is done right and I think that building codes in most of the US require nails over screws.
4. The original install had the walls done first and then they poured the floor -- I had to carefully chisel the old wall tile out 1 inch or so below the level of the floor. I assume it would be OK to fill these cracks with new mortar and ensure proper slope and then install the floor tile first. Let that cure properly, cover to prevent damage while I then install the wall tile -- this method to me seems like a better way to ensure less chance of leaking since the wall tile is over the floor tile, but I could also install it the same way as originally done-- walls first and then butt the floor tiles up to them. I suspect that they did it the walls first and then floor to save time and prevent damage to the floor but maybe there is some other reason I am not thinking of.
I may be over thinking these things as I typically do but I would appreciate hearing from the collective wisdom from the Pros on FOG.
Thanks in advance,
Scot
Thanks in advance,
Scot
