Brice Burrell
- Mar 13, 2007
DD, here in the States we use these terms for cutting crown, cutting "in position", this is the with the crown held on its spring angle upside down. Here's a pic of crown set to be cut "in position".
[attachthumb=#]
When cutting in position the crown is upside down (also referred to as upside down and backwards). The portion of the crown that sits on the wall is the part that sits on the saw's fence and the portion that goes on the ceiling is on the saw's bed. Cutting give you two benefits, first its much easier because you don't need to use a compound miter (just a miter cut) and second, the pencil mark to cut the length will be facing up, where it is easy to see and align. One of the possible downside is you need to remember the crown is also backwards, what is the left end on the saw is really the right end of the piece as it sits on the wall, just don't forget that and you'll be fine. As you said you do need a large diameter blade to make this cut, that's the other downside.
The other term used here is cutting crown "on the flat", setting the crown flat on the saw bed (with the profile facing up). The disadvantage is you'll have to cut with a compound angle. To determine the compound angle you need you first have to know the crown's spring angle. There is a formula for the saws setting for each spring angle, however, its a lot easier to get your hands on a chart with the of setting for each spring angle. Do a search on the net and you should have no problems finding a chart. I don't cut on the flat unless I have to because it is a little more complicated setting the angles. Sometimes with large crown I have to then I have to find my chart.
[attachthumb=#]
