question on parallel guides
kev carpenter
Hi i just bought the guides for making my owen kitchen units but didn't realise that it only goes to about 660 and units are 720 the only way i can do it is turn the stopper back to front or use the extension guide on the back of it any suggestion or can you buy a ad on.
Hi
I'm sure this topic must have been covered here before but i can't find it.
I've just purchased Parallel Side fences and extensions( 495717 & 495718) and I need to set them up accurately. The instructions supplied are a joke. Can anyone point me towards a video or detailed instructions on setup.
Thanks in advance
I cut an accurate 200mm block on my SCMS to use as a gauge when calibrating the guides.  Mark a tooth on each side of the blade on your saw with a felt marker and use this tooth against the gauge block to set the stops when they are clamped at 200mm.   8)
