- Sep 10, 2014
Hi Folks,
I was setting up an STM 1800 today and ran into a couple of questions. The first step was to screw metal tubes to some sacrificial pieces, I think European beech, through holes in the tube. In your experiences, should there have been pre-drilled holes or should I just wing it....also, they were specified as PZ1 but appeared to be a very small Torx screw.
Second question....in the instructions, the next step is specified as screwing the caster housings on with some 8mm drive cap screws with a washer. I received both a flat washer and a lock washer for each caster. I assume that both of them go under the screw.....25 n M torque IIRC. Finally, one of the, what I call aircraft, nuts on one of the caster hubs was missing....I guess I'll run over to a hardware store for a replacement....once I get these issues ironed out, I will perhaps share my first impressions.
