Dr. P. Venkman
tekaddictnyc said:When I use the TSO PG with GRS, I rip a 5mm edge to start. Then reference that edge with the TSO PG flip stops to the parallel dimension I want. For that parallel rip cut, the GRS is not touching the edge of the plywood. I leave a small gap. Only the flip stops touch the fresh cut edge. After I have 2 parallel edges on the panel, then I use the GRS against the fresh edge to begin cross cutting.
Ha! You're a faster typist than me, but that's what I was getting at. Having the GRS "disengaged" from the material is the only way I can see to stay parallel.
I still don't understand TSO's claim of "square and parallel in a single cut."
