Frank Pellow
- Jan 16, 2007
I have read about several different techniques for squaring the rail on a Festool Multi-Function Table (MFT). Here is a method that I use particularly when I am off-site and need to quickly saw or route some wood.
These pictures were taken in my shop but I don't often use this technique there because my MFT 1080 is set up and ready for work about 90 percent of the time using the "standard" fence and mitre gauge. Off-site, I usually utilize a MFT 800 and the fence and mitre gauge are sometimes not with me and even when they are with me the task does not require their use.
I have two old, made in Canada about 30 years ago, Black and Decker workmates , and they have 20 mm holes and each came with 4 bench dogs to fill the holes. Actually according to my micrometer the holes are 19.9 milimetres in diameter ?exactly the same as the holes in my MFTs.
Following is an illustration of the steps I take to get my folded up MFT ready to crosscut a board at a 90 degree angle:
1) Unfold the MFT and set it on it?s legs.
2) Place three Workmate Bench Dogs in appropriate holes in the MFT then set a straight edge and a good carpenter?s square against them.
[attachimg=#1] [attachimg=#2]
The straight edge that I use is most often a Veritas, made in Canada, 38 inch aluminium one (Lee Valley: 05N63.03) and the square is a Shinwa, made in Japan, stainless steel one (Lee Valley: 60N48.01).
3) Line up the rail with the square then set the support mechanism on the front edge of the MFT.
[attachimg=#3]
Note that I quite often (about 75% of the time) find that no adjustment is needed because things have remained square from the previous use.
4) Set the wood to be cross cut against the bench dogs and hold it in place with a couple of Festool Clamping Element clamps (Festool: 488030). Lower the guide rail and place the saw upon it.
[attachimg=#4]
Then saw.
I just tried the above set of steps in my shop starting with a folded MFT and the saw and other tools in their boxes and it took my less than two minutes before I was able to make the cut.
[attachimg=#3]
[attachimg=#4]
Then saw.
