stvrowe
- Jan 27, 2007
When I ripped up the carpet and padding from my master bedroom in preparation for laying hardwood flooring, I discovered some rather uneven seams. Some spots were as high as 1/8" from the adjacent sheet of ply and this just wouldn't do for a new floor installation. So I went to my Festool armory and pulled out the RAS 115 and a 24 grit Saphir disc to take some high spots down (actually quite a few high spots). This thing cut through nails that I hadn't set low enough, plywood , paint, drywall compound, construction adhesive, and cementitious leveling compound in very short order (about 45 minutes for an entire 17.5' x 14.5' room). Only one disc was used and no loading was noted. Dust collection was pretty good but not perfect. It was better than I expected for a sander of this type and seemed to have more difficulty collecting dust from grinding the leveling compound than anything else. I did get pretty aggressive with the sander and caused it to slow several times but it recovered quickly when pressure was reduced. When I pulled the disc off the pad, there was some partial separation of the loop material from the Saphir paper so I ended up trashing the disc even though the abrasive itself had a lot of life left in it. I have a 4x24 belt sander that I opted not to use for this project as I figured I would be going through belts right and left (come to think of it, I haven't used that belt sander in the past 10 years since I purchased my first Festool sander).
I really hadn't used the RAS 115 much and had only used it to scribe a few post formed vanity tops. As I continue the home remodeling effort, the RAS is going to get a lot more use. In the future, I may just leave the disc on the pad to see how many rooms it will complete before requiring replacement.
