rblau said:
I have a lot of exterior trim work that needs repainting and I am considering the RAS 115 for help with removal of old paint and prepwork. From reading posts here, the consensus seems to be that Saphir 24 would be the paper of choice for the initial removal phase.
I used Saphir 50 this week to strip very hard (I think oil-based) paint from a house with my Rotex. The paper cut through the paint like it was butter. I was appalled though by the damage done to the wood beneath the paint leaving hideous scratch marks. I'm going to get me some 80 grit Saphir for the rest and see how that works, I think it will do very nicely too and perhaps leave a better wood surface.
Considering what 50 grit already does, I know I myself am NOT EVER going to use any of the coarser grits like 36 and 24. And I would advise anybody against it unless your work surface is absolute horror. Also, the Rotex was so aggressive with the Saphir 50 that I would not need a RAS at all. I originally anticipated this job to be though so I even had my 10.000 rpm Elu angle grinder fitted with sanding paper, but I didn't need it at all.
rblau said:
But I was wondering what would work best for the next step. Would the RAS with Rubin in 60 or 80 work?
I wouldn't advise Rubin as it is for bare wood but stick with the specialised paint papers like Cristal and Brilliant. Cristal 40 and 60 are great for leveling rough paint and to leave a nice preparation for the primer I smooth it out with 80 grit Brilliant on the Rotex and the Deltex.
rblau said:
In general, what grit do people generally sand to in preparation for painting with an alkyd primer followed by a few coats of a good exterior Latex?
I generally prepare the surface with 40 or 60 grit Cristal or Brilliant 2. If I got Cristal I prefer that since it is tougher and more aggressive. If I'm out of Cristal, Brilliant 2 will also work, it just take a tad longer. Then I finish it off with 80 grit Brilliant to leave a smooth surface for the primer. On wood outside it's really not necessary to go to higher grits. The wood is rougher and the primer (I prefer a high solid primer, always) will fill out a lot of uneven spots and scratches.
Between the primer and the finish paint I only do a quick hand sanding with a 120 grit sanding foam pad.
About Latex ....... I don't know about what climate you live in exactly, but where I live, here in The Netherlands, I would NEVER use latex on wood. Always alkyd paint. I leave the latex for stony surfaces only.
Oh yeah, when working on doors inside I go up to grit 220 or 240 to get a really smooth result. It's more important there.
