RAS 115 help please
tdfiver
Hi I have a RAS115 and after fitting the soft sander pad I now can't get it off !!
any ideas ?
I have struggled with that sometimes too. I can't remember if you can slip the wrench in there to help out or not.
If you remove the brush from the shroud you will see a large slot you can get a pressed steel spanner through
