as Shane rightly pointed out you do need a spark trap when grinding metal with extration they are however not cheap so if you only have a small amount of work to do on metal it may be worth considering not using extraction if circumstances permit.Redfox said:Thanks Shane, I'll look into that.
Cheers,
Jacques.
Festoolfootstool said:as Shane rightly pointed out you do need a spark trap when grinding metal with extration they are however not cheap
Redfox said:though I always prefer smal ones, because of the narrow spaces underneath cars etc. 115mm - 600watts and 125mm 750watts. I never liked bigger ones with bigger discs.
