recent furniture, guitar building
I have this upper back issue that's been taking a long time to heal so I've been focusing on getting some things done I've had in mind for quite some time.
Walnut dining chairs.  The back, seat rail and rear legs are steam bent walnut.  I found kiln dried walnut steam bends adequately in these sorts of non-extreme bends.  I use a backing strap and end block from Veritas.  Setting up for any one shape, making the form and all that is time consuming but the bending itself is a rapid process.  The slats are bent  oak.  A slight s-curve was achieved by rapidly bending each slat both ways against a curved form using the back strap in order to crush the cells on both faces.  Then they were clamped to dry on a form made to the slight serpentine profile.  They are springy so I didn't have to get the curve perfect, just close enough so I could stick them in the mortise in the crest rail and clamp and screw them into a "half mortise"  in the lower  frame.
[attachimg=2][attachimg=3]
This is another bent wood chair prototype... this time in oak.  The oak had been sitting around drying for a long time and the part I used for the back surface-checked when steam bent.  The front legs are slightly bent off the corner and the seat frame is bent on the same form I used for the walnut side chair above.
[attachimg=4]
7 string guitar I had in mind to build for several years... used in Brazilian music and other styles.  I had bought a Brazil made 7 string some years before and played it for a year or two before selling it.  It took me at least 4 more years to get around to building one.  There are compound teardrop soundhole cutaways one either side of the neck.  They do help the player hear better what's going on and left hand access to higher frets is a little easier.
Your work is FANTASTIC! And WAY out of my league.
How long have you been making chairs? These obviously aren't anywhere near your first!
Thanks for the praise. The guitar is my fifth.
Before building these I built a few study chairs from books out of scrap wood.  I did one not-bad prototype from a book but rather than go ahead and build it again I decided to do a chair with a curved back rail.  Then I built an oak cafe chair frame  (never glued up) from  Jeff Miller's book and decided I could do something more interesting with the back.  I did several iterations to figure out the back angles and all that so it felt right when I slumped against the back.  I was sawing leg profiles out of construction 2x4s and screwing them to a plywood seat mockup with 2 pine front legs, moving pocket screwed back parts up and down, adjusting angles, adding and subtracting..  I haven't made that many but I've been thinking about developing some original chairs for many years.  I do designs to sell so it's important they incorporate original-looking features in order to avoid lateral price comparisons with furniture store product from potential buyers.  The wood bending is something I got into because I was looking at chair designs in books with sawing curved backs out of these thick pieces of (for me) expensive lumber and laminating up other curved parts which seemed slow, wasteful and messy.
Very cool! I built an electric guitar a long time ago. Did the fret layout and all. It was fun. My dad has built a couple acoustic ones. Tons and tons of time. Again...very beautiful work Loren!
