leakyroof
- Mar 23, 2011
. Thanks for the info. Having lived in Chicago since 1989, I am aware of some of the Electrical Codes. Was creating this thread to work with one or more electricians so I understand what's at stake in the easy planning stage.tjbnwi said:Use this housing;
http://www.homedepot.com/p/Halo-5-i...Air-Tite-Housing-6-Pack-H5RICAT-6PK/202707602
With this trim (allows you to select color temperature);
http://www.homedepot.com/p/Commerci...egrated-LED-Recessed-Light-53186141/300035875
With this dimmer (works at multiple stations);
http://www.homedepot.com/p/Leviton-...er-White-Light-Almond-R01-DSL06-1TW/206942378
Done..
I believe Peter_C was referring to switches at multiple room entries. 3 or 4 way switches that control the lights.
Also, it is a code violation for anyone other than a Chicago licensed electrician to do electrical work in Chicago. The city will not issue a permit to anyone other than a Chicago licensed electrician, not even the homeowner can get an electrical permit from the city.
https://www.cityofchicago.org/city/en/depts/bldgs/supp_info/electrical_inspections.html
Forgot to mention-use this hole saw on your plaster ceiling. Avoid joists, that can ruin your day.;
http://www.homedepot.com/p/Milwaukee-5-3-8-in-Recessed-Light-Hole-Saw-49-56-0303/203113613
Cut a basket ball in half to collect the dust.View attachment 1View attachment 2
The basketball ball trick is an old one, still a good one for plaster ceilings ..... [wink
No rush on this job, we've got hot irons all over the place in 3 different properties right now.... [eek]
