I'm ready to start installing 1x6 Beaded Pine T&G on my porch ceiling and am looking for some tips on layout. I have six lengths: 8', 10', 12', 14', 16'. There are 24 pieces of each length except for the 10' which is 30 pieces. I will run the wood parallel with a 32' span. The rafters are 16" OC and with the way everything worked out on framing, there is a rafter right at the exact center point of the 32' span. I'll be starting at the outside end of the ceiling (away from the house).
I'm looking for tips on how I use this assortment in the best fashion so I don't end up with a lot of weird short pieces or butt joint patterns that don't look random. Also, should I use 2x16' pieces for my first row? Would I want to strategically place any 2x16' pieces as I go? Such as at the midway point, or 1/4 points, etc?
As far as the rest of the install, everything is pre-primed and pre-painted on both sides, as well as the tongues and edges of the grooves. I'll paint the cut ends as I go. I'm planning to leave 1/4" - 3/8" gap around the entire perimeter for expansion. All butt and T&G joints will be fit as tight as possible. Any concerns with this? Fasteners are 2 1/2" 16ga stainless steel finishing nails.
Any since people like pictures, here's the stack of wood. Miter saw is a DW717 10" slider with Freud LU79 blade.
Here's a better shot of the ceiling
