nickao said:The way Matthew formats his pictures to be so big and clear, yet stay within the limits of the forum picture size rules is great!
Nick
Michael Kellough said:... My pictures are puny by the time I get them below 125k.
Matthew Schenker said:Michael Kellough said:... My pictures are puny by the time I get them below 125k.
Changing a photo's pixel size is not the only way to reduce it's KB size. In other words, you don't necessarily have to reduce a photo's dimensions to get it to under 125KB.
Quite often, you just need to reduce the quality from 100 down to 75 or 80. That makes no apparent difference in the screen quality, but the file is reduced quite a bit in KB size. The easiest way, for me, is to use a little free program called Irfanview.
Matthew
Matthew
Michael Kellough said:.......... I've been lazy and only using iPhoto which doesn't seem to let me do that.
Hopefully it does and someone will instruct me.
Scott W. said:I don't have 6 to check but make sure you have selected Jpeg as type(kind)
Quality only shows up after you select Jpeg for type(kind)
You can also size in preview during the save as process
And you can use graphic converter (applications - Might be in utilities folder)
Scott W.
