Reducing Signature Point Size.
Stephen B
Is there a way to reduce the point size of your [size=13pt]Signature?
[size=8pt][member=1674]Peter Halle[/member] [member=1619]SRSemenza[/member]
[member=19746]Untidy Shop[/member]
I just discovered that there is a way:
[ size=8pt]type what you want in your signature line[/size ]
You will have to omit the space between the left bracket and the word size at the beginning and also the space between the word size and the right  bracket at the end.
My signature below is 4 pt type as an example
Pater
I don't know if you want to do this.  By reducing the size of his signature it gave Peter a new name.  Welcome Pater
Thank you [member=1674]Peter Halle[/member] for researching this. It worked to my satisfaction. Changed font size to 8pt and Font to [ Font=Arial]. Readers should remove the space before 'Font= ' for this to actually work.  [smile]
