Nitrous888
- May 15, 2025
Hello,
I changed the chassis and brushes for an old Festool 150/3 EQ excenter sander, and now there is a spark between the commutator and the brushes, also the armature and the coil is overheating after like 2 minutes of idle usage, so that is not normal of course.
One thing I need mention, I needed to change one of the coils wire because it broke and it looks like a 0.75mm wire, so my electrician friend changed it with 1mm wire and he said it should work, but I read somewhere it should be a problem with the resistance, so we'll change it to 0.75mm tomorrow and we'll see.
So, my question is, do you have some ideas what could be the problem? It making me insane, I tried so many things to make it work, but no luck.
Thank you!
Thank you!
