Regular vs. Pro Osmo polyx oil
ear3
What's the difference between the regular and the pro Osmo Polyx oil?  The specs say the pro requires less cure time, which would be a plus for me on the project I'm starting, but is it less foolproof/tougher to work with than the regular Osmo?  My application includes both flat surfaces/panels and moulding, done in oak/oak veneer.
You can email (info@osmona.com) Osmo NA or call them on 800-515-4168 for more info.  They're on the left coast and 3 hours behind the east side.
I would also do a search here on FOG as I swear some of our Aussie or UK members have commented on both those oils and their pros and cons of each... [unsure]
I talked to the Osmo folks today, as per Sparktrician's advice.  Since I'm going to be doing a fair amount of paneling and moulding (rather than flooring), it was recommended that I go with the regular rather than the pro.  Which is fine -- I've used the regular stuff before on some bathroom cabinets and it came out great.
I was told by a flooring manufacturer that osmo pro is for use in osmo machines. E.g. For pre-oiling flooring before its sold to customers. (Which ties in with the shorter dry time)
Osmo is beautiful stuff. Easy to apply, looks good. Makes the grain pop....
