Scott B. said:
Yes, 1000 sf in a day is reasonable. A guy would have to average a 10x10 square for 10 hours to achieve that. It is doable. Especially since he is not suffering from claw hand by wielding too heavy of a sander. RAS is great for the first two hours or so on vertical. After that, production takes a nose dive.
I'm starting to think you guys must be using water paint. I could never do such an area in 1 hour, let alone keep at it for 10 hours straight. Our oil based paints are simply too hard and thick for that.
Scott B. said:
Most clap reveals here are 3-5", and we all know what happens when the sander is too big for the surface.
I use the RO 150 and RAS 115 for such jobs. With the RO 150 dust extraction is still very good. The RAS is messier indeed, but the time won is more important. People don't want to hear a job is going to cost them 50% more because you need your time with a smaller sander.
Scott B. said:
I don't know if you sand whole houses or not. We do several per year, with many painters from season to season. So, what I am sharing here are observations based on those experiences.
Wooden houses are extremely rare here, everything is made of stone. But we do have garden sheds and "temporary" wooden cabins that then stay up for decades, so large wooden surfaces do come up once in a while.
Scott B. said:
On the abrasive side, and again this is a reflection of the reality that I do this day in and day out all day long, one line of abrasive...granat. Much easier to inventory, stock and create consistency from job to job and crew to crew. Other lines can do certain things better here and there, but across the grits for paint sanding, granat does the best for us in the variety of situations we encounter.
I can understand the need to make it not too complicated in a company with many employees. But I've noticed a serious time gain using for instance Saphir 50 over Granat 40 to strip paint with the Rotex. Saphir is simply that much sharper and lasts a lot longer. Like 10 or 20 times longer. So for me the choice is easily made. I am really glad there are so many choices in Festool's sandpaper line up, so I can get the optimal one for every situation.
