This is retrospective review of the bestselling vacuum in the NA. As a happy owner one of the best vacuum in the world for more than four years, I want to share my experience with this tool. Yes, indeed CT-26, is slightly better, but CT-22 has its own benefits. Festool USA currently offers CT-22 for $454.50, but for the limited time you can buy one for as low as $363.60.
[attachthumb=1]
First at all this is not just a vacuum, this is dust extractor. Dust control is an integral part of the Festool system and design philosophy. CT-22, and it’s bigger brother CT-33 shares the same platform.
Some specs:
Dimensions: 24” x 15” x 17”
Weight 12 Kg (26.5 lbs)
Noise level: 62 dB (low setting) 72 dB (max. Setting)
Maximum suction capacity 134 CFM (3800 l/min(
Power consumption 350-1200 watts
Container/filter bag capacity 22 liters/20 liters (5.8 Gal/5.3 Gal)
The standard scope of delivery includes:
- CT-22 vacuum
- 27mm x 3.5m (1-1/16” x 11.5’) antistatic hose
- HEPA filter
- One disposable filter bag
- Shipped in cardboard box
[attachthumb=2]
What makes this dust extractor outstanding among other brands vacuums?
1. HEPA filters as a standard. Yes, unlike Fein vacuums, CT-22 goes with 0.3 micron HEPA filters as standard.
2. Electronically regulated suction.
3. Tool activated power switch
4. Antistatic hose.
5. Low noise level
6. Wide selection of accessories includes cleaning kits, various houses (27mm – 50mm), boom arm, suction holders, handle etc.
7. Compatibility with systainers
8. Integrated brakes.
9. Dry/wet vacuum.
[attachthumb=3]
[attachthumb=4]
It might be impressive, but why to buy this particular dust extractor? The answer is extremely attractive price. (Hurry up, this deal won’t last long).
What I like in CT-22.
Lower than CT-26 profile. CT-26 has un removable hose garage, that makes it almost 4” taller than CT-22. It’s not and issue in the shop, but in the small van or truck every inch is valuable.
[attachthumb=5]
Brakes. I found that older stile brakes a little bit more comfortable. CT-22/CT-33 has two brakes near rear wheels.
[attachthumb=6]
Exhaust port. This is very rarely used function, but it might be helpful when sanding some smelly materials.
[attachthumb=7]
[attachthumb=8]
Another function which I’m missing in my CT-26 is cord storage hooks. CT-22 allows having them with handle/boom arm attached, CT-26 doesn’t.
[attachthumb=9]
Suction start is very smooth. Noise level is extremely low. It is much lower than any tool attached to this vacuum especially on lower level of suction. CT-22 has very convenient handle on the top for caring this vacuum.
[attachthumb=10]
[attachthumb=11]
Festool produces and sells wide variety accessories. All cleaning accessories can be used with other Festool vacuums.
Which accessories are worth to look at?
CT 22/33 handle 452921. this handle improves mobility, and required for mounting boom arm.
Suction hose holder 487072. This holder brings hose to workbench level
Boom arm 492753 It keeps the cord and hose up and out of your way. This boom arm can be used with CT26/36 vacs, but required additional bracket.
Conclusion:
This is an excellent vacuum for more than attractive price.
[attachthumb=1]
Some specs:
- CT-22 vacuum
- HEPA filter
[attachthumb=2]
4. Antistatic hose.
5. Low noise level
9. Dry/wet vacuum.
[attachthumb=3]
[attachthumb=4]
[attachthumb=5]
[attachthumb=6]
[attachthumb=7]
[attachthumb=8]
[attachthumb=9]
[attachthumb=10]
[attachthumb=11]
Conclusion:
