batmanimal
afish said:If you are going to start doing cabinet work you will need a router and the LR32 is HIGHLY recommended. Im not a huge fan of Festool routers its similar to the Kapex for me just not enough benefit over the others to justify the price difference and the non centering copy ring irritates me on such an expensive tool it just seems like for the money these basic bugs should be a non issue. For me my favorite plunge router is the Dewalt DW 621 the trigger is a little to get used too but otherwise its a solid machine and was way ahead of its time with the built in dust collection. However it wont bolt up to the the LR32 base plate without getting creative. So the 1010 is ideal for the LR32 MAfell makes some nice stuff but not sure I like it. I dont like how the anti chip feature works mainly. Otherwise it looks like a great saw. However if you had went with the Festool you could have already had the LR32 track as part of the package. Not sure how flush you are but if budget is an issue I would have kept the 780 return the kapex and get the LR32 & 1010 instead. Unless you have a crew or need a saw for at a site and shop 2 SCMS is overkill. As I said though it really depends on budget and space. You will also need a good as large as possible cutting station. Its a process to develop a system that works for you and typically not cheap. There is a whole list of accessories on your horizon. parallel guides, track hinge, MFT drilling systems, edge banding equipment, guide rail squares, and on and on. Good luck.
I wish Mafell/Bosch offered something comparable to the LR32. I know the Mafell saw can use the festool rails, so hopefully it would work on the LR32 track. I might just bring my Mafell to the dealer and check it out in person.
I was thinking of selling the Dewalt saw / mobile stand combo, but I am weirdly attached to it. (It is so hard for me to let go of any of my tools; yet, one of the justifications for investing in Festool is that I know that, worst case, I could likely recoup much of what I spent on the Festool product in the resale market...) I am planning to use the Dewalt to build a treehouse once the weather clears up. It is so good for cutting PT posts and beams.
For cutting station, I can only fit a ~4-6' wide table in my space for the track saw MFT, so am thinking I will put everything on wheels, and have an auxilliary set up like the dashboard outrigger that I can add as needed, and move into position after moving the cars out of the garage.
I also need to figure out how to do the long cuts on the miter saw. I am planning to use the MFT as the extension table to the immediate left of the saw. I was thinking of using the dashboard pws long fence as the extension fence and adding a cut stop to that fence. (I have gotten lots of good ideas from the workshop section of this forum!)
