So I am currently working on a home that is being rehabbed to sell. The owners wanted to have the popcorn ceiling removed in two rooms. I figured this was a great testing ground to give the Planex and Ct 36 a try. What makes it even better is we are doing the work time plus material and the house is largely empty. I figured there was nothing to lose!
So along with the sander and vac I ordered the harness, blast gate, extra plastic collection bags and some various sandpaper.
Everything arrived today and I arrived at the job around 1:30, and got the vac and sander unpacked and setup by 1:50. Not bad at all [big grin]. I then gave it a try on the ceiling and quickly decided to setup the harness. It seemed to be a bit less self explanatory and I spent the next hour sanding a bit and adjusting the length. So by about 2:30 I had everything where I thought it felt reasonable and really got down to business.
Took me about an hour to finish off the 12x14' kitchen ceiling using 80grit. I still have to go around with a smaller sander to get a few spots that the Planex had issues with. Above the fridge there was not enough room for the head to fit and around a few can lights that I just didn't want to get too close.
A few learning experiences:
Use the blast gate and Manual clean much more often, I noticed in the beginning that I had dust falling out of the holes around the edge. I brought the sander down and flipped it over and a mound of dust fell out all over the floor.
When using the blast gate don't forget to open the gate again before starting to sand again, I did this only once and in the few seconds the head was on the ceiling it instantly filled the room with dust. [scared] Thank god the house is vacant!
Overall I am pleased with the results so far, tomorrow I have the 14x30 living room to do and then I have a good number of tape joints to fix that will have to be sanded. I'm hoping that I got through most of the learning curve today.
One question though... Back to the harness. I am still not 100% sure that I am using it correctly. Does anyone have any tips? I have it adjusted so it rests on my left leg and I found the most comfortable way to use it was sorta sideways with the sander bar and harness bar the same distance from my body and with the sander head almost vertical. I was then controlling the sander with both hands next to each other, one on the sander and one on the harness bar. I hope that makes sense. [tongue]
Thanks!
[ Edited to correct spelling of "Planex" - Shane ]
Thanks!
