Long time reader, first time poster.
I have the MFT/3 with the CMS/VL extension.
I'm using the TS55 mounting plate along with the rip fence that fits the MFT/3-VL (http://www.festool.com.au/rip-fence-for-cs-70-mft-3-vl)
The issue I've been having is repeatability setting the fence square without a lot of fiddling and measuring.
The fence clamps hold the fence square once set, however, it's far too easy to setup a fence that isn't square with the table/parallel with the blade. I assume this is partly the design as there is play/movement on the rear clamp before you lock it into position and therefore when moving the front of the rip fence, either by hand or using the micro adjuster, the back of the fence does not move at the same rate.
Any ideas? ???
Thanks for any help
Any ideas? ???
Thanks for any help
