Jmacpherson
- Jun 9, 2016
Hi all
This is my problem, I need lots of different 32mm wide narrow strips of various lengths for shelving unit.
Here where I'm located you can get something called Cover Strips in either Pine or Meranti which come in 3 metre lengths X 8mm X 32mm/44mm.
I can find 32mm Meranti which is too dark for my needs but all the retailers either have no stock of 32mm or don't stock it.
Then I remembered I can get PAR Pine in 220mm X 32mm and that the FS guide rail is +/- 185mm wide and will comfortably fit on a piece of lumber this wide.
If I place 2x pieces next too one another will be even more stable.
I have the 32 tooth blade for the HKC55 which gives nice cuts in my opinion, I've used it to trim a door previously.
It doesn't have the splinter guard of the TS55 which would be better suited to this but if I used masking tape on both sides of the wood and I obviously take the width of the blade into account would I be able to make my own strips with clean enough results?
