ripping on the mft
Bertotti
SD
Well, no table saw here so I am using the mft and my 3000mm rail to do the job. I broke the rules if there are any and moved the factory stops on the table alignment stuff and mounted it on the sides with the 3000 rail. The boards were floorboards so taking the tongue off one edge then ripping to width. There will be a block under the rail to set the width and keep all the boards equal. I don't have a bunch of fancy jigs so thought this was an easy consistent workaround. Anyone else tried this? I can't be the first. I was hung up moving the blocks for the rail holder but in the end, I was always adjusting it anyway so figured what does it matter.
Things are a bit messy but its my own house so no biggie and my wife doesn't care as long as I make progress.
