mandatory66
- Nov 26, 2015
I just received a new RO 90 and plugged it in to insure it runs. To my amazement the bottom section of the sander by the air vents started to heat up. The heat after running about 2 min. extended to the back section of the sander. The heat seemed excessive and I am wondering if this is normal as I have not read any comments about the sander running hot like this. The sander was in ROS mode (fine) Should I return the sander or is this normal. There were no unusual sounds such as grinding noise etc.
