Hello,
I tried to strip some exterior paint off a gable using my newly acquired RO90. I have used Granat P60 and the paper quickly clogegd. But the clogging mode got my thinking whether it may be more my technique than the paper: it looks like paint flakes are coming off the surface and then stick to the paper. I tried to reduce pressure and suction but the effect stays the same.
clogged disk (Granat P60)
Is there a better paper to try? One of my next projects is sanding a small deck where the paint is failing (and pressure washing did only remove the loose paint). Any recommendations regarding the paper I should try?
Thanks,
Johannes
Thanks,
Johannes
