idratherplaytennis
- Jul 6, 2015
So. I am more or less a newbie when it comes down to it on the Festool stuff- having recently purchased a RO90 and an ETS EC 150/3. I am not much of a newbie to sanding etc etc- I have the gist of that down, and I've seen dozens and dozens of videos of the rotex and other sanders- so I know what they are capable of.. part of why I got one.
HOWEVER... I have come across an issue. We are sanding down about 30 years of varnish or some sort of clear-coat on 30+ cabinet doors and drawers, and the two sanders are going at it like champs- I actually have to be very careful not to eat through the veneers (I'm used to a 2.6mm orbit finish sander- not random orbits to say the least, but I'm getting the hang of that..). The issue is we have 2 well used cutting boards, but they are still quite flat- yet they need a massive overhaul in the sanding and re-finishing department. I knew the rotex was the way to go so that I could get down past all the gouges (the tenants used them well for the last 25 years) and burn marks, however after a minute or less at 80 grit, as suggested per my local guy who I got the sanders from, there was massive buildup on the granat paper. I was able to clean it off pretty easily with a wire brush just gently scraping it back and forth- but this leads me to believe I need to do some sort of prep work for sanding down the cutting boards.
Does anyone have any recommendations on how to do this? I tried doing a few searches, however I mostly only came up with 2 methods- one or both of which could possible be questionable. One suggests washing the boards really well with hot soap and water, and probably the scouring side of a sponge, while another method which I read more for cabinet doors and drawers, suggests getting the grease and muck off with mineral spirits. I'm not exactly in a time constraint- but I do want to get this all done sooner than later and I figure if I need to really wash the boards well- that will take at least a day (in the current Southern California heat) to adequately dry out before I can attempt to sand them.
Anyone else have any opinions? Normally we would have just tossed the boards and bought new ones and done a lot of cutting down work to make them fit the existing cabinets, but because the boards are pretty darn flat- I thought this would be a great opportunity to give the RO90 a work out (and more then that... to prove the justifiable expense to my Dad [big grin])
Edit:
For clarification, I ran the RO90 with 80 grit Granat at a 6 speed with max suction on the CT26. Not sure if for the heavy duty stuff, the 6 speed is too high. About to go read anything else I can find in regards to this.
Edit:
