Sparktrician said:
Why not make your own
insert for a systainer? I made this insert to accommodate the grits that I normally use. It's easy to see which grits are running low. When I get back to the shop, I replenish as necessary. I've never run out of any particular grit on a job site. I'd have to be working with some pretty gnarly stuff to go through 100 sheets in a day. Just sayin'...
Willy, was just looking at your thread, the original image still shows, but the other images further down in your post are missing. I do prefer the way you've set up your partitions, as the sheets stay in place better than when stacking up as the Festool insert would have you do.
Gary
