Ajax Carpenter Carl
- Apr 12, 2018
I have a Rotex 125 sander. It was purchased November 2012. It is not a tool that we use often and mostly sits in the shop. Last summer the variable speed stopped working.
I just had the sander sent to Festool Canada through Atlas machinery, I was told it was going to cost $368.00 plus tax. I was also informed that the bearings needed replacement along with the electrics. When I mentioned that I had no issue with the bearings I was informed that this was discovered upon inspection. I was not prepared to pay for bearing replacement on a unit that gets used maybe 2 times a year. I was then informed that if I did not want to complete all of the repair they would not do any repair and I could have the sander returned but it would be returned disassembled.
For a high end tool company I find this unacceptable. If this was all explained to me, I would not have sent the tool in as it worked fine prior to being sent out. Has anyone had similar experiences with repair? I realize it was out of warranty and did not expect any free service, although I think it should not have happened considering the slight use this tool gets.
Are Festool parts available for purchase only?
Any advice would be appreciated.
