clisbyclark
- Feb 24, 2007
Any and all feedback will be greatly appreciated-especially those who have used both. If the sortainer is your choice, what drawer configuration works best for you? thanks
clisbyclark said:Any and all feedback will be greatly appreciated-especially those who have used both. If the sortainer is your choice, what drawer configuration works best for you? thanks
Quick and dirty off the top of my head you could epoxy a zip tie into a slot in each plastic (or wood) block. If you used a thin one it would bend out of the way for insertion and spring back for lifting. It occurs to me just now velcro is bad around saw dust though.Corwin said:I was also thinking along this line... but, I would like to have individual blocks with little handles on them such that I can simply grab the handle to place/remove the block with the desired cutter. That way there would be less chance of getting cut from a bit when putting it in or out of its storage compartment. One day...
Corwin
poto said:.
I've also been eyeing those brass bit holders at Lee Valley (http://www.leevalley.com/wood/page.aspx?c=2&p=56500&cat=1,46168) and thinking of making a plastic insert for the Systainer with the brass holders for the bits. Might work...
Tom, this is not at all pretty, but I use a single page spreadsheet trying to show locations of various bits in the Festool insert. I posted an earlier version of the way I use the insert (sys2 rather than sys1, etc.) in this thread. I've since replaced the compressed polyester with pieces from the much more appropriate foam insert set (p/n 487427).tvgordon said:Do you guys label the bits? If so, how do you do it? Right now I just store the bits in the plastic sleeve or box they came in because it has the size stamped on the front. It would be nice to have them out of the packaging (I was looking at the systainer), but I would also like to know at a glance if I'm grabbing a 3/16" or 1/4" round over bit.
Tom.
