It will take most router bits without a problem but if you have the long bits, like the 70mm two flute cutter for a lock jig then those are too long to close the lid on the Sys 1.
In which case your options are keep those in their plastic protective sleeve and just lay them in the Sys 1, or get a Sys 2 as Alex said.
