derekcohen
- Jun 22, 2008
I have a decent collection of both 1/2" router bits, and these are my general go-to for use in a large Elu (think DeWalt DW625) and my main router table. I also have 1/4" bits for use in a smaller Elu MOF97e (think DeWalt DE621) and a Makita trim router.
Recently, I decided to build a second router table around a spare Makita trim router, and then I began wondering whether there would be an advantage in switching to an 8mm collet for 8mm router bits. The 8mm has four times the surface area of a 1/4", and the advantage of greater stiffness and less flexing.
I then began searching for 8mm router bits, and discovered that the range available is small, and the more modern designs are only really available from sources such as AliExpress. For example, other sources offer bits which are the "old style", for example, there are no carbide, spiral or compression bits on sale. My question is why is the 8mm size not preferred and promoted over 1/4"? Do others here use 8mm?
