semenza
Zaphod said:I'm probably in the minority; but I view the lifts as a solution to a nonexistent problem. I've used a PC 7518 for years in a standard insert plate. Changing bits couldn't be easier or quicker; lift the plate, unscrew the motor; use the two wrenches to loosen the collet; takes all of 30 seconds if that. IMHO, two wrenches are easier to use than trying to hold a lock with one hand and use the wrench with the other hand. I have a 1400 for non-table use and like the ratcheting collar but it's still not as convenient as the two wrenches on the 7518.
Changing heights with the big PC is trivial; loosen the locking lever and rotate the motor. The 7518's depth ring is graduated in 64ths; easy to eyeball to ~ 1/256. I played with the Woodpeck 7518 lift at a Woodcraft; nicely made and worked as advertised; just didn't didn't add any utility in my opinion. Perhaps other routers benefit more from the lifts.
Zaphod
I use two wrenches with the 7518 in the PRL in the table. The lift makes the height adjustment more convenient and dead on precise. No pulling the router and plate out of the table or going underneath loosening motor, adjusting, tightening motor. I find this especially useful when having to make several small height changes in a row gettiing something to be just right. If you need to move the bit up or down just insert crank , turn, remove crank. Repeat as needed. Quite literally five seconds, perfectly precise amount, and easier.
My feeling is that once you try a lift in the shop you would never want to go back. Not knocking your method , I am just saying why I like the lift better.
