You could add the “Extension table” VB-CMS/CS 50 to your CS50 as both a widening table to be used with the LA fence and a module to drop in a router. Festool’s CMS-OF drops in this table with very little mod. You could also make your own module to drop in. The table is the same length as CS50 and CMS-GE so you can utilise the V grove in the same manner.
Pictured in the snip from the PDF manual for VB-CMS/CS 50 is the CMS-GE with CMS-OF - But CS 50 would look the same.
[attachimg=2]
[attachimg=3]
