Rule/Square/T-Square/Combination Square lengths
HDClown
Outside of the "get 1 of every size" approach, do you have a particular length of rule, t-square, square, combination square, etc. that you tend to find yourself using the most?
12" combination square and 30cm ruler, 150mm ruler, 4" engineers square, 3' straightedge, 12' metric/ imperial tape measure.
I have a few others but these do 99% of what I need.
When I don't need to use a guide rail, the 6" Swanson Speed Square is the one I use most frequently off the MFT.  On the MFT, it's the Woodpeckers 450mm Precision Carpenters Triangle.  Then there's the 3m Talmeter tape measure.
This kinda depends of the sort of stuff your making.
The bigger the item, typically the bigger the square you'll need or want for accuracy.
I have 4", 6", 12", and 18" combination squares (the 4" is a double square).  I use the 6" most.
I have 6", 12", 24", and 48" rules.  I use the 24" and 48" lengths most.
What?  Are you really supposed to measure and make sure things are square?  This bit of wisdom may improve my work.  [big grin]
Woodpeckers 1281 square, combination square, speed square and fast cap tape measures.
I have LOTS of traditional machinist squares from years of being in that industry. They are mostly poor for woodworking. I do use the 4" double squares, and sometimes a 6" double square a lot. These are used as often for making a depth gauge as for a square. If you want a repeatable line at 1/2" just move the square to that point and leave it there. I actually have 4 4" double squares and 2 6" and wouldn't want to do with much fewer.
For a traditional try square with the bonus of markings, I have a Woodpeckers 1281 square that is heavily used. It is vastly superior to the traditional machinist square in the same sizes but the Woodpeckers is less flexible so sometime I do resort to the 4 piece machinist square. With drawers full of various squares, probably 20 in all, I probably use the 1281 and a couple 4" double squares as much as all the rest put together.
Really happy that I invested in the Woodpeckers 32" T-Square.  Great for cutting up sheet goods, setting down a straight marker when domino-ing a wide panel, and I also use it (or a line that it created) on a scrap board to quickly square my MFT.
Rockler sells a relatively cheap assortment set of engineer's square, which I use for marking edges, short boards and squaring up my stationary power tools:
http://www.rockler.com/3-piece-engineer-square-set
