Packard
Time is the enemy of offensive odors (except cat piss). Odors eventually fade.
I have been using the oven since the “event” and it does not seem to be affecting the taste of the food I have heated up.
I will still take the suggested remedies and go with them. Sort of like chicken soup for the ill—it may not help, but it can not hurt.
There is a technique for making a RainDance like effect, where raindrops simply fly off the windshield by using raw potatoes. You cut the potato in half and rub the exposed cut against the glass. Note: If your windshield wiper breaks and no replacement is available, the potato-against-the-glass can get you out of a jamb.
I will use that same technique with the apple and again later (if required) with the lemon. It is not going to cost much, and it is not much work (and I like Farmers’-Almanac-like advice). I will report the results.
