Hello,
this is my first post here and I want to share my drawings of sacrificial fences for the kapex 120.
the drawing is in the svg-format with 72 dpi. The drawings are made to cnc the fences instead of building them by hand.
I made the fences using 6.5mm birch plywood und used M4 washers between the lower fence and the kapex to raise it to 7,5mm thickness. Works very fine. The drawing is quite precise as you can see from behind. I used M6 countersink screws, washers from the backside and big round nuts which can easily used without tools to dismount the rear fences. The fit exactly inside the green levers of the two back fences.
Hope, someone can use this to cnc his own, without creating the drawing, which was not as easy as I estimated before.
Best wishes from Bochum / germany
martin
martin
