Bob Gerritsen
- Feb 10, 2012
This is a bit of an emergency, I have to finish a walnut table tomorrow (although I could delay it with another day if needed) and want to do this with an oil/varnish mix.
From what I understand I need boiled linseed oil, polyurethane lacquer and turpentine, right? This is the first time I want to make this mix in Switzerland (used to work in the Netherlands) and so far I've noticed some things can be hard to find. So I need to know what the deal is with this oil/varnish mix. For instance, can I use NON boiled linseed oil? What exactly can I or can't I use for solvent? And the same with the varnish or lacquer (not sure if there is a difference as English is not my first language), what can go in and what can't?
I've looked for boiled linseed before but have only found non boiled, there's plenty varnishes out there but I do not know what makes a good candidate exactly so cannot make a proper decision when picking.
I realize my questioning is rather broad but the thing is I will go shopping for the ingredients tomorrow and I'm not sure what I'll find. Meanwhile I no very little on this subject or finishing in general (it's on my to read up on list...) so need all the knowledge I can squeeze out of you.
Let's call it Maloof finish for dummies.
All advice input is highly appreciated!! Thanks in advance.
Cheers! Bob.
Btw, It's bedtime over here so pardon the delay in response.
Cheers! Bob.
