I just sand the edges with 150 to get them smooth, spray the primer, snad with 320 grit or 240 and as long as you spray the recommended wet mils you will be good to go for paint.toadjeep said:Are you prepping the routed edges of the MDF in any way before you spray or does the primer do a good job of that?
JYip said:My past experience with using a water based primer on raw mdf is that it will raise the “grain” on the surface of the mdf causing tiny bumps (almost like goosebumps). The edges will not seal despite the amount of coats I put unless I “seal” the edges first with something like joint compound or bondo. I was left with no choice but to use oil/solvent based primer like Zinsser coverstain. Can you share your experience and what you did to solve these issues? Thanks
Jeff
Before priming I use the DTS400 with 220 grit granat, as mdf is already sanded to 150. Once primed I use a sanding pad with 320 grit and hand sand the profiles by hand using foam backed paper, also 320 grit.jaguar36 said:What are you using to sand these?
I've been looking at the Supermax brush/drum sander that they claim will do raised panel doors, curious how well that would work on profiles like that.
JCLP said:This has 2 coats of primer and sanded smooth as glass with 320 grit. Primer used is Duralaq Undercoater. Door built with MDF.
JCLP said:JYip said:My past experience with using a water based primer on raw mdf is that it will raise the “grain” on the surface of the mdf causing tiny bumps (almost like goosebumps). The edges will not seal despite the amount of coats I put unless I “seal” the edges first with something like joint compound or bondo. I was left with no choice but to use oil/solvent based primer like Zinsser coverstain. Can you share your experience and what you did to solve these issues? Thanks
Jeff
Yes. I have had that issue with other primers. Any primer will raise the "grain" to some extent but I found the Duralaq Undercoater did a great job especially when you sand it with 320 grit after 2 hours of drying. Make sure you spray on the recommended wet mils. Don't spray too thin.
Cheers,
JC
