GPowers
- Mar 1, 2010
Would be very cool if there was a sand paper punch-plate that would cut the new Multi-Jetstream holes in to existing Jetstream sandpaper.
I have a whole systaner II full of the old style Jetstream150mm discs, several hundred. Most likely more then I will use in five years.
I can buy a new STICKFIX SANDING PAD with the new hole pattern, but I have $200 of old hole pattern jetstream 150mm discs. The punch-plate would allow me to punch the addition holes into the old paper disks.
I have an old Bosh sander that came with a paper punch so you could use standard 1/4 sheet sand paper by using the paper punch as a size pattern and to cut the hole in the standard paper.
A paper punch for the Festool 150mm old style disk would only need to punch the additional holes.
