Dear all,
I am planning to buy a Festool sander, for indoors renovation work, and hobby-woodworking. The projects I have planned currently are:
1. Removing carpet and paint from old stairs, to be treated with varnish or oil afterwards.
2. Renovate doors. I will need to sand the old paint to remove paint drops from the previous job, fill up holes and damages, and finish with a new layer of paint.
3. Renovate wooden chairs. Currently varnished; I want to remove the old layer, replace with oil or wax.
4. Sanding a table I’m currently making new, from oak, will also be finished with wax or oil like the chairs.
So, I consider two options:
1. RO125 and DTS400. The RO125 is good for doing larger surfaces for coarse sanding, the DTS should be used for coarse sanding in corners on stairs, and for the fine sanding on all projects. Disadvantage is the money ofcourse.
2. RO90 with the delta pad: Seems good enough for the stairs, and I can get into tight corners. Finishing step should be better than RO125, because of the smaller amplitude (3mm vs 3.6mm). However, I don’t think it’s very easy to keep the tool flat on the table top or doors, because of the smaller area… Advantage is the less money spent ofcourse.
So, my concern in buying the RO-90 is that I buy something that is multi-purpose, good at many things, but not as good as a specialized sander. And that in the end I will end up buying a larger RO125 for larger surfaces, and the DTS for finer finishing… which in the end will make me pay 3 tools, instead of 2…
Please share your opinion
Thanks,
Jan
Thanks,
Jan
